FlexRadio and Heil mic?
sp8s
sp8s Member ✭✭
Hi
I have older Heil mic - GM-4 the gold series, with Icom's plug. Is there a way to use it with Flex?
Stan SP8S
  • KlausP
    KlausP Member ✭✭
    Hi Stan,
    Since this GM4 is a dynamic microphone, it should work with Flex without any problems.
    Only the plug needs to be changed, as these multipole plugs are not usable with FlexRadio.
    The microphone has an 4-Pin XLR connector and the 8000 FlexRadio series has a TRS 6,3 mm jack
    Ready-made cables for this are available in music stores.
    73, Klaus
