Power reading in the TGXL Window in Smart SDR for Mac?
Dirk Schuurs
Good day.
In SmartSDR for Mac there is a separate TGXL Window which is showing the the Fwd Power and SWR. The Power-bar goes up to 2000 Watts, but in my case I use only max 100 Watts. Question: is it possible to adjust the Power-bar in this Window to a lower power-output than 2K (for example max 100 Watts?). See picture attached.
Dirk HB9GPN
I find that mine shows a max of 200W though I've never run more than 100W through the TGXL. I suspect, like the SWR bar, when the number exceeds the current scale, it changes the scale. Have you ever run beyond 200W from your amp? Perhaps just once is enough to change the scale to 2000w?
- 322 Shack Infrastructure
- 227 Networking
