How to connect PGXL to VLAN when setting up SSCR 4.1.3
edwinhigg
I am using a VLAN for SSDR 4.1.3. Specifically, I am using a Cisco C1200 8-port model. My computer ,my 6700 and my TGXL all connect easily using URLs from my gateway. The PGXL will not connect. Sometime, quite on its own, It will connect using a default URL. Has anyone had any experience with this?
Can you configure the switch port as an access point and set up a VLAN on the switch side?
I think you mean IP address and not URL.
Sounds like possibly a power outage and the PG boots before the DHCP server on your router is up and running. Also make sure nothing is blocking the discovery packets from the amp to the DHCP server are not being blocked.
73 Dave wo2x
- 685 The Flea Market
- 195 SmartSDR+
- 102 Aurora
- 994 Maestro
- 971 Genius Products
- 357 Tuner Genius XL
- 133 Antenna Genius
