CW Skimmer & Flex / Replaced Dual Monitor with a New Curved Monitor
Bob
The X and Y position of the CW Skimmer window is remembered and much probably now it is out of the range of the new monitor.
I'm not sure if you can easily edit some Skimmer related file/register to reset the coordinates.If not, try the following: (no success guaranteed)
Reset Individual Application Windows
If a specific application window is in an undesirable location (e.g., off-screen), you can use a built-in Windows trick:Hold down the Shift keyandright-clickon the application's icon in the taskbar. (If the window is maximized, first click "Restore".)From the classic context menu, selectMove.Press any arrow keyon your keyboard once to activate the move function.Move your mouse(without clicking any buttons) to bring the window back onto your visible screen.Click onceor press theEnterkey to drop the window in its new position.
Alternatively, holding down theCtrlkey while closing an individual window can sometimes reset its next opening position to the default, provided the application supports this function.1 -
Would you happen to know the Registry folder?? The Lat and Lon apparently need to be reset to 0,0.
If you get no answers or help I can install Skimmer and search for the registry keys
I've searched the Registry for Afreet and CW Skimmer with no luck. Any thoughts on what to search for?
If you are in rush and still have it, reconnect a second monitor and move the Skimmer window to the curved.
Possibly other applications can have the same issue.
Thanks, now perfect!!
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
