Multi-Flex - Where Did It Go?
I don't use my Flex Radios too often to notice this was missing. Recently I updated to the free version 4.xx. The way I use my Flex is with both the PC software and my Maestro. Now when I fire up my Maestro I get a message saying that a version of software is running on my PC and asks if I want to disconnect from that software in order to use my Maestro. I use to be able to run both through my Multi-Flex software that I bought part of the version 3 upgrade that I paid $200 for. Now the Multi-Flex option isn't even in the menu to turn on or at least that I can find. Don't tell me that Flex made that a pay for option with version 4 that I already bought in Version 3, and it was in the release notes!
David
K9AT
David,
Just start the second copy from the radio chooser. Nothing special. And does not matter which order they are stared in. Use the MultiFLex tab under Settings to set which instance gets PTT response. Its always been that way.
AL, K0VM
Thanks Al for the reply. Well after doing more investigating I noticed in the menu with the Maestro under "Radio" off to the right it said licensed for version v2. I hit the refresh button and in popped v3 and with it Multiplex reappeared. So this case can be closed.
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 949 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
