When would one engage the ALC and how would that be done?
David43
My setup,
8600M, PGXL and at times operate remotely using a Maestro C.
Hi David, with the combination that you have, you do not need to use the ALC at all. The ability to use the ALC is for compatibility with older equipment and should not generally be used with modern gear.
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
