Multiple Antennas Same Band AG 8X2
For example, I have 2 antennas for 40M. How do I use a specific antenna without manually selecting it? Let's say I am working a local station using one antenna and then I want switch to the other antenna for DX.
The AG User Guide states:
"When there is more than one antenna available for a particular band, AG will return to the last antenna used for that band when that band is selected."
Can someone clarify this?
This is correct, if you have assigned 2 antennas to a band in the AG utility, when you move to that band e.g. 40m you should see 2 buttons, the previously used one will be selected as default and if you want to change it, you just click the other antenna.
Thanks Rich. I suppose that makes sense.
Although the extra tuner memories may be useful (there are additional tuner memories, right?), don't see any advantage to the manual switch I'm currently using.
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
