ESC - Feedback
Not sure if or when Flex ESC will work well or not, but in general using other radios and/or external units, the key is to design a good noise capture antenna. One that targets the offending noise source. The actual configuration of this noise capture antenna takes time and effort. A lot of design work and experimentation. People that don't do the ant design work, tend to complain that the phasing and noise canceling doesn't work well. But, it does work well in most cases if the noise capture antennas is planned and implemented well. Designing a noise capture antenna is like the opposite of designing a good RX antenna for max S//N. Dan de WA1QZX
My experience using ESC on a Flex 6600 is the same as that of Mr. Krueger's above: when I increase gain (.02) from 0, the S meter increases to S9 + 30 dB as if the noise rx is over-loaded. I added a 13 dB attenuator in line with the noise ant (Rx B); same result. It does not seem that Flex has the additive process working correctly. I've used an ANC-4 and that was quite effective, but the Flex ESC is not.
The noise is from a bad lightning arrestor on a 19 kV line about a 1/2 mile away. I have a repair order with the utility. I was hoping that I could null the noise using the ESC feature. I am using a 43' (60m) vertical as the noise antenna, the 75m antenna is a pair of inverted vees at 100'. I have tried the ESC feature on several bands with different antennas, same result.
73, Steve, K0SF
@Trucker Dunno. I thought I wanted a noise antenna, a 'lousy' antenna — that is, I want it to pick up very little signal, just noise, so that its input can be more-easily subtracted from the actual listening antenna. But now I'm wondering if that's not how ESC actually works, b/c I plonked a fairly short vertical antenna 5' from my (presumably relatively noisy) IT rack and despite much spinnin' of the ESC knobs, I have not yet achieved grinnin'. I thought somebody had linked or posted an official FRS video demonstrating ESC doing the thing, but I can't seem to lay hands on it at the moment. Maybe over the holidays I can put up the vertical outside the house at different/greater lengths, see if I get different results.
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
