Audio Muted After Transmit
Gary
Gary Member ✭✭
I am still having an issue with audio being muted after I transmit if ESC is on and one of the following noise filters is on. (NR, ANF, NRL, ANFL) Other noise filters work as expected. I can correct the problem by turning the offending noise filer off. If I turn the noise filer back on and transmit again the same issue occurs. If there are no noise filers set there is no problem and this does not happen if ESC is off. I have tried a factor reboot but this did not correct the problem.
How do I fix this issue or is this a bug that still needs to be fixed?
Gary
K9GWS
    Hi Gary, this sounds like a bug. You should submit a help desk ticket. Include everything that you can to help Flex Support recreate the issue.
  • Gary
    Gary Member ✭✭
    Thanks, Len just sent in a help ticket.
    Gary
    K9GWS
  • n0mdh
    n0mdh Member ✭✭
    I just ran into this several times today. I knew it happened on diversity, but I probably had ESC enabled as well. I cannot recall which filters were enabled though. I opened up a ticket and it's been forwarded to sustained engineering.
    FWIW, I've been able to get it working again by changing to another band. E.g. I move from 20M with the problem to 40M and get audio immediately. When I return to 20M, I still have audio.
