Mac-native CW Contest Setup
Equipment List:
FLEX-8600M
MacBook Pro (Apple Silicon) running macOS 26 (Tahoe)
SmartSDR for Mac (DL8MRE)
SkookumLogger (K1GQ)
Belkin USB-C to 2.5Gb Ethernet Adapter
WKmini - WinKeyer 3.1 (K1EL)
Ethernet cable (shielded CAT6a)
Keyer paddle
Heil Sound Pro Set Headset
Proposed Setup & Workflow:
Mac <> FLEX-8600M: Ethernet Cable (via Belkin USB-C Adapter).
Mac <> WKmini: USB Cable.
WKmini <> FLEX-8600M: 3.5mm Keying Cable (from WKmini Key Out to Flex Key In). This handles the actual RF triggering.
Paddle <> WKmini: 3.5mm cable into Paddle In. Allows for manual keying.
Headset <> FLEX-8600M: Plugged directly into the radio's headphone/speaker jack for zero-latency monitoring.
Data Flow:
CW Keying: A macro is triggered in SkookumLogger. The text is sent via USB to the WKmini, which generates the pulses. These are sent as electrical closures to the FLEX-8600M’s rear key input.
Frequency/Mode Logging: SkookumLogger connects directly to the FLEX-8600M over the Ethernet link using the native TCP API. Changes made on the SmartSDR for Mac interface or the 8600M front panel are reflected instantly in SkookumLogger.
Audio Monitoring: Audio travels directly from the Flex radio to the headset (no DAX or network audio involved in the monitor path).
Motivation / CW Timing Issue:
I understand that CW sent via software through SmartSDR CAT can sometimes experience latency or jitter due to OS polling. By using WKmini hardware keying, I am aiming for "weight-perfect" timing even at high contest speeds.
Questions for the Community:
Has anyone implemented a similar stand-alone, Mac-native contest station using the FLEX 8000/6000 series with SkookumLogger and a hardware WinKeyer? If not, have you found a method that works?
Are there any specific settings in SmartSDR for Mac or the 8600M front panel I should watch out for to ensure the rear-key input is treated as a straight-key closure (disabling internal iambic)?
I’d love to hear about others’ experiences or any optimizations you’ve discovered.
Thanks in advance!
Bill, K8BTU
Howdy Bill!
That's a nice pick-list you have! I would suggest you give Software Defined Connectors (SDC) a try for your CW keying and contest logging, versus Skookum and a WinKeyer. For some mysterious reason, the Skookum author doesn't like Flex, thus its integration is inferior to SDC and it's unlikely to get any love.
I think SDC's skimmer is fantastic, and it's eye-watering collection of features and solid Flex integration make it a compelling choice. While setup is a bit arcane, the support is fantastic, especially for a free app.
You've probably also given it some thought, but the upcoming Aurora is a pretty compelling product too, especially given its power, weight, and integration. The only possible wrinkle would be 120VAC power in the field. I'm not a field operator, but an Aurora 510 is in my near future.
Good luck!
Hi Bill, you should really try SDC, it works extremely well. During the installation, you may have to run a command in the Terminal, otherwise macOS security tends to block it. Once that’s done, it runs flawlessly. You just need to send $20 to Yuri to get the SmartSDR API. The author is very responsive, and honestly, it’s well worth it.
https://www.lw-sdc.com/
73's Jean-Luc / F5JRC1 -
Not sure about those winkeyers. Perhaps you can give a look at the MorCoNI project.
Hi Bill, Jean-Luc, and N5NHJ!
Thank you for the information on Software Defined Connectors (SDC). I will download the software, check out the manual, and watch some of his videos. It looks like a much better alternative to Skookum and WinKeyer.
Bill - I absolutely considered the new Aurora product. As you noted, however, there is no method to power the unit from a battery (which is understandable since the Aurora likely runs at a much higher internal DC voltage to achieve its power rating efficiently).0
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
