Iambic setting bug
I work with Iambic A. But every time I restart Maestro, Iambic B is active, although iambic a is still marked in the settings. Only after a short tap on B and then back to A does it work as desired. Can others confirm this? Should hopefully not be a problem to be correct in a FW update.
The bug is still there, unchanged. Is it really such a big challenge to fix this unwanted automatic fallback to Iambic B?
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
