Problems to log in windows and remote.
Hello all,
call is ct1drb and my name is David Quental.
I have a flex6600 and it has been working very well, but maybe yesterday I did a downgrade to v3.10.15 to test a equipment, I think it was a bad idea.
I did test and then I upgraded to v4.1.3 in my macOS computer and seemed that everything was fine. But some time ago I went to windows computer, started SmartSDR and I did not get flex6600 working and situation remains.
On macos computer I do not have problems to work with radio but on windows it is not possible, also remote is not possible to work, or, it starts apparently well, but without a slice, and when I create a slice it looses connectivity with with radio. Radio at same time does a reboot.
So, I feel that I did something very wrong but if someone could help me to solve this problem will be very good.
Best 73 all.
CT1DRB/OK8RB
David Quental
    Hi David, I think that you need to do a factory reset. Export your profiles first. If that does not help, submit a help desk ticket.
  • ct1drb
    ct1drb Member ✭✭
    Hello Len,
    how are you doing?
    OK, tks a lot, your suggestion solved indeed my problem.
    Best 73 and till next time.
    CT1DRB/OK8RB
    David Quental
    Hi David, I'm glad that helped!
