Function Button diversity mode
I would like to suggest to the FRS engineers to diversify the Memories on the master based on the operating mode, if I operate in SSB the Function keys must recall the DVK memories, if I am in CW they must recall the CW macros. It makes no sense as it is currently that I cannot set F1....F2...F3 on the master because they are used for Send CW. Furthermore, I have verified that there is a bug if you select a DVK memory in a function key, the same is recalled in another function key not allowing you to diversify them in the various function keys... try this to understand the problem.
It seems that no one is interested in this possibility, what is the point of having function keys assigned to CW calls if you are in SSB, it would be nice if they were dynamic based on the mode of activity, or create DVK memory keys on an area of the LCD to have direct DVK calls
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
