FT8 and FT4 Simultaneously
Geoff AB6BT
Geoff AB6BT Member ✭✭✭
I hace 2 panadapters on 15 Meters. And 2 instances of WSJT-X. One is FT4 and the other is FT8.
When I make a transmission on FT8 the transmission is stopped halfway through at the end of the FT4 cycle.
How do I fix that?
  • David Decoons, wo2x
    the radio cannot transmit on two frequencies at the same time.
    73 Dave wo2x
  • Geoff AB6BT
    I uinderstand that. I'll rephrase my question.
    I am monitoring 2 instances of WSJT-X on 15 meters, one configured for FT8, slice A, and the other for FT4 slice B. Each one has its own panadaptor.
    Slice A is set as TX. When I transmit using FT8 on slice A, the transmission is stopped about halfway through at the end of the FT4 cycle. I am not trying to transmit on slice B.
    I launchjed the 2 instances of WSJT-X using Slice Master. I did notice that SM changed the radio ports in WSJT-X. I have 2 TCP CAT ports designated for the 2 instances, Slice A is 5002, and slice B is 5003. When I use SM to launch WSJT-X it changes the ports to 7381 and 7382 respectively.
    Any clues?
  • Geoff AB6BT
    I see that SM does change the ports as mentioned in my previous message. So, I don't suppose that is of any concern.
    I'm still trying to track down the FT8/FT4 problem.
    I'd really appreciate any assistance.
    Thanks!
    have you tried to just create two TCP ports in SSDR CAT? 5002 for slice A and 5003 for slice B. Then create separate shortcuts for slice A and B following this video.
    https://youtu.be/muYUYfaU02c?si=xkeScEQgwdKC3YwT
    This will test to see where problem is located.
    I do not use SliceMaster.
    73 Dave wo2x
  • Geoff AB6BT
    Dave…That's worth a try. I remember looking at that a while ago and I belive I gave it a shot. Frankly I don't remember the outcome.
    Some folks were raving about how using SliceMaster was the way to start multiple instances of WSJT-X so I thought I'd givre it a try.
    I'm off to work this AM but hopefully I'll have time this evening to check it out.
  • Geoff AB6BT
    Well, I did set up icons for 2 slices per the video, both on 15 meters in their own panadapters. One on FT8 and one on FT4. With both instances of WSJT-X open, Transmitting on the FT8 slice terminates after 6 seconds, the end of an FT4 cycle.
    So…the behavior is the same.
    Any Ideas?
  • Geoff AB6BT
    I'm going to try 2 slices in 1 panadapter to see if anything works differently.
    We'll see.
  • Flexed
    Flexed Member ✭✭
    edited December 2025
    @Geoff AB6BT It appears that both instances of WSJT-X are attempting to transmit at the same 15-second interval, which needs to be adjusted. For example, configure WSJT-X A to transmit at 00 while WSJT-X B receives at 00, then have B transmit while A receives. Ensure the highlighted settings are changed so they are not identical on both instances.
    Make sure Full Duplex is enabled. Also, if you’re using two antennas, check that the bands aren’t interfering with each other. Depending on the antenna locations, BandBypass might not provide adequate protection.
    Look at this, I even received a QSO on 20m and 17m. What a great example—enjoy it!
    [ ] Tx even/1st is checked on the left, but unchecked on the second instance. I can receive and transmit on both, but only transmit one at time.
  • Flexed
    Flexed Member ✭✭
    BTW, I'm not using slice master for this setup.
  • Geoff AB6BT
    Flexed…Thanks for the ideas. I have tried this with and without Slice Master. the results are the same
    I was never trying to transmit on the FT4 frequency and the radio never looks as though it is transmitting on the FT4 frequency.
    I do not have full Duplex enabled.
    I'm not sure if one is odd and the other even, I'll have to check later. I'm not sure why this would make a difference in my example.
    What seems odd to me is that FT8 transmisssion stops at the 6 second mark of the FT4 slice. That is before the transmit cycle begins.
    I'll try your suggestions later today.
  • Flexed
    Flexed Member ✭✭
    @Geoff AB6BT I have run into this before, trust me it's that check box. Anyways try it an let us know. Full duplex will allow to listen while you are transmitting, but I'm not 100% if it is on the same BAND will be the same. With 2 Antennas while my 20Meters is transmitting I'm listening on my 17Meters, so depending of what are its your goal you might need Full Duplex.
  • Geoff AB6BT
    Wednesday update…
    The same condition exists as before after making the following changes:
    I selected 1st for FT8 and 2nd for FT4. FT8 slice is TX and FDX enabled.
    FT8 transmission is stopped (no RF output) at the 6 second mark.
    One thing I hadn't noticed is that while the RF output stops, the WSJT-X progress bar continues to move to the right in TX mode. Does that make sense?
  • Flexed
    Flexed Member ✭✭
    Are you on the same Bands? If not, could you try out different bands? For example, let’s try 20m FT8 Instance 1 and 30m FT4. If you can send a video, that would be great! I can duplicate it at my station.
    The issue you are having is for two cycles of FT8 there are 4 cycles of FT4. (FT8 at :00 and :30 while FT4 at :00, :15, :45
    So if FT8 were to start transmitting and FT4 started receiving, half way through the FT8 transmit cycle FT4 will want to start transmitting.
    If your goal is to have FT4 and FT8 both calling CQ, it will not work. You can however have two slices open to have one listening to FT4 and the other FT8.
  • Geoff AB6BT
    OK, I guess I'm not explaing what I'm seeing.
    I was never attempting to transmit FT4. I was transmitting only on the FT8 frequency and listening on the FT4 frequency.
    That is why I don't understand why the FT8 transmission is truncated halfway through when the FT4 slice is receiving only.
  • Flexed
    Flexed Member ✭✭
    @Geoff AB6BT Which radio do you have and how many antennas?
  • Geoff AB6BT
    8600. I was using a C4 for the two 15M frequencies. I have others but they were not in play.
  • Flexed
    Flexed Member ✭✭
    Check this out FT8 transmitting and FT4 listening keep in mind that while FT8 is TXing FT4 will stop listening. If you want FT4 to listen the full time then you need two antenna, and full duplex on.
    Here is the view with two antennas an full duplex Slice 2 will never be stopped from receiving but you need Full Duplex on and another antenna at least that's my way of doing it. Hope this make sense
  • Geoff AB6BT
    I appreciate you taking time to reply with your setup.
    I still do not have an answer to my question regarding what is causing the FT8 transmission to stop.
  • Geoff AB6BT
    More data…
    I have slice A on 20M SSB, 14.215 USB. I open the WSJT-X instance configured for FT4 without opening a new slice. There is no slice B.
    The CAT TCP port set for the slice B, 5003, shows "Not Present".
    At the end of the FT4 cycle, the radio changes frequency from 14.215 to 21.140.
    But this only happens when The FT8 instance of WSTT-X is open and configured on slice A at 21.074. Also, The FT8 instance changes frequency to 21.140!
    If I manually switch back to 20M the same thing occurrs.
    Confusing HUH!
    What the heck is going on?
  • Geoff AB6BT
    I'm bumping this with the hope that someone besides me has experienced the same problem.
    I'd open a support ticket but I'm sure they are pretty busy…
    Thanks in advance.
  • Geoff AB6BT
    Update.
    I believe I've found the cause of truncated FT8 transmissions.
    I found that if I exit ACLog the FT8 transmission runs to completion.
    I have emailed Scott. Hopefully he will have a solution.
  • Geoff AB6BT
    Scott replied that he doesn't have a solution…😕
