Receiving this error repeatably
This exception is preventing me from using SmartSDR 4.0.1. SmartSDR crashes directly after this exception is displayed
Hi Doug, try a factory reset after exporting your profiles. I'm pretty sure that will fix it. If it doesn't, then submit a help desk ticket.
You might try a factory reset of the radio…
AL, K0VM
This suggests the error is software.
But if it's because of a corrupted data base leading to a software error, that is good info for the programmers to know. A factory reset clears the database. And it would get you back in business.
AL, K0VM
Al is correct. I had one today concerning CAT but I had been playing with ports so a radio reset cleared out the EXCEPTION.
Lar, K1UO
It is a software bug (SMART-11479) related to the Hardware ALC function. The factory reset would turn that off, which is why that bandaid likely has helped some.
If you are intending to use the Hardware ALC function, you may need to back down to v3.8 which didn't have this version or wait until a fix is available.
I have a similar problem with a similar error message except it is a function of frequency and method of entry. I am attaching my notes and maybe someone can suggest solutions. I'll open a ticket in a day or two if I cannot sort this one. The radio is useable but with these error depending on frequency.
Hi Lionel, if you haven't already, export your profiles and do a factory reset. If that doesn't help, submit a help desk ticket.
Thanks Len. I've done that a couple of times and no improvement. I just now had the 6400 crash but no comm loss error. Odd. At the time of the crash the data rate on the 6400 showed excellent with <10ms latency.
I'll do the factory reset again, maybe third time is a charm.
Curiouser and curiouser….I think I am having fun today, true.
And if all else fails, and I am afraid it will, then off to the ticket we go.
Thanks Len
73 Lionel N5LB
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
