NR in V4, no adjustment, but there is!
So with the new V4 basic the NR on SSDR is either on or off with no adjustments. But there is adjustments possible with FRStack REST using /api/ActiveSlice/NR. I have that REST command assigned to a StreamDeck+ knob and I can most certainly adjust something that is changing the NR settings.
So I guess my question is what is the "fixed" setting in SSDR that would correspond to FRStack REST level (0-100)?
Or am I just holding it wrong?
You are not wrong in my estimation and I reported this at the outset.
For me and my noise, power pig on a pole in an adjacent field that affects 80m, I have 50% correspond to the fixed setting. This does not mitigate the noise at all unlike previous SSDR versions that had sliders. The effectiveness of those versions can only be matched by increasing the level in V4 to circa 95%. But this is probably not universal and other users will see a different level to effectively deal with their noise environments.
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
