After upgrading, SmartSDR shuts down
You might want to export your profiles, then do a factory reset. If that is not it, try a direct connection between your 6300 and computer. If that solves it, you likely have a network issue. If not, then you should submit a help desk ticket.
Same thing here… Did a factory reset and it works fb now. But where is the ESC thing? I can’t find it.0
Hi Dave, what radio do you have?
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
