Flex 8600 & Slice Master v0.11.0 Not Working
New Flex 8600 owner ( back to Flex after 2 yr hiatus) and can not get the current version of Slice Master to work for me. Running SSDR v4.0.1 on Win11 PC. One of the reasons ( lots of others) I came back to Flex was it's ability to integrate so nicely with CWSkimmer. So frustrating problem.
Have tried uninstalling SM and reloading- no joy. I keep getting a msg at bottom of SM window AttributeError: Traceback (most recent call last) and if I go into the SM log, it lists:
Traceback (most recent call last):
File "flex\flex.py", line 1309, in publish_updates
File "cwskimmer.py", line 511, in daxiq_stream_cb
File "cwskimmer.py", line 310, in local_streams
File "flex\radio.py", line 629, in local_iq_streams
File "flex\flex.py", line 308, in getattr
Any suggestions on a work around or a solution? I have tried contacting K1DBO but no responses back.
73 Paul w2eck
If you just want a skimmer have you tried SDC, no need for Slice Master as its all done through an API.
Great support from Yuri and others here on the community.
https://www.lw-sdc.com/
Hi Paul, SliceMaster does not work with the newer Flex versions. I don't know if Don plans on updating SliceMaster or not.
I switched over to SDC like Rich did and it works great. Here is a link:
Len & Rich
Well guess I to will have to make the switch also. Thanks for suggestions. Hope learning curve not too steep.
73 Paul w2eck
I ran into the same issue when I upgraded my 6500 to 4.0.1.39161 this evening .. My Slice Master v0.11.0g stopped opening all the various apps .. I noticed an anomaly that Slice Master WOULD work and open the apps when I choose a profile that used all 4 pan adapters on my 6500 .. After some research then going into my DAX menu I noticed ALL my IQstreams and RXstreams were turned ON even though I only choose a one pan adapter screen ... I tried turning OFF all the IQstreams and RXstreams except the one being used and I was able to get Slice Master to work correctly ... So for me, turning off the unused streams before starting Slice Master allowed Slice Master to open all the programs as it should ... Just a work around until a fix is released ...0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
