Shorted to ground my powered speaker connection
What would I have done for damage....and do I need to send my new 8400 back to repair any damage?
Thanks for any advice!
Bruce NIMZI
Have you tried plugging in a set of powered stereo speakers to see if you have actually damaged something? The rear speakers jack outputs a line level audio signal that needs a set of powered speakers in order to have any volume. It does put out a very low level ( volume) signal that you may not have been able to hear on your mono speaker. There is a possibility that you damaged something. But, I would suggest trying powered ( stereo) speakers first before sending the radio off for repair. Even if you have damaged the line level audio output, once you get your radio back from Flex Radio, you will want the powered speakers.
Or, you could just operate the radio from your computer and direct the audio to your computer and attach powered speakers to your computer.
Thanks James……just realized that I never made contact with the Kenwood mono jack into the flex…sorry for my comment!
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
