FT8 Operation Concern
Ernie
Ernie Member ✭✭
When using FT8 with a Flex-6400 with Windows 11 SmartSDR v4.0.1, configuring SmartCat to use TCP with WSJT-X Slice A, TCP: Port 60000 (default) Slice Auto Switch TX. Setting the WSJT-X Network Server: to localhost:60000 will not connect to SmartSDR, but if I use the radios IP Address everything appears to work.
I would appreciate comments.
  • Ernie
    Ernie Member ✭✭
    Added - in my previous V3 localhost:60000 worked.
  • Ernie
    Ernie Member ✭✭
    My bad. I had a typo that I did not catch.
    All is working now.
    Apologies to all.
