Bug in version 4 affecting radios using v1 or v2
Just received email from Eric Wachsmann with FlexRadio that says “Unfortunately, there is a bug that causes v1 and v2 licensed radios not to be able to connect.  We apologize for the inconvenience.  We will have this fixed in the next point release scheduled in ~2.5 weeks.” He later said it might take 3 weeks or around the first of December 2025 to fix bug in version 4.
  • Jim Draker
    Jim Draker Member ✭✭
    Tried going from V2 to V4 tonight and didn’t work. Got only 1/4 of the top screen with no radio ID, no profiles, nothing worked. So I bought V3 thinking going to V3 would help, Nope it would not even load V3. I don’t know what to do now? I did wait and hit hit the refresh button for V3 then it went away still wouldn’t load … So now I’m back at V2 and works but the radio info says V2 max version?
  • WX7Y
    WX7Y Member ✭✭✭✭
    did you do a HARD reset and Power reset when you loaded V4
  • Dave M.
    Dave M. Member
    Eric helped me with my 6600. He made my ver 2 a ver 3 which brought everything up….but after I turned it off, it would not reconnect. A factory reset cleaned it up, works fb now. However I can’t find the ESC function. Is it being debugged?? Any way the radio works good now.
