SmartSDR+ ESC
Mick  W8BE
Mick W8BE Member ✭✭✭
edited November 2025 in SmartSDR+
Looking at the release notes it shows that only the 6600(M) and 6700 can use ESC for the 6xxx series of radios. Is this a type. I would think if a 6600(M) can run the feature a 6600 should be able to as well. Also please clarify the last sentence in the release notes. How is the metering affected?
Best Answers
    Answer ✓
    Hi Mick, the parenthesis in "6600(M)" indicates that the 6600 as well as the 6600M are both covered.
  • Mick  W8BE
    Answer ✓
    Thanks. Do you have any information regarding the metering comment?
    Regards
    Answer ✓
    I think that means that the S Meter reading will be affected by nulling or peaking a signal using ESC.
