New licensed feature in API or CAT
OE1MWW
OE1MWW Member ✭✭
edited November 2025 in SmartSDR API
Assuming the new features are licensed, will it be possible to enable, disable, and trigger them via CAT or API? I am particularly interested in CWTune, as I have implemented this function for CAT in my software for Kenwood.
73's de OE1MWW, Wolfgang
  • Eric-KE5DTO
    Yes. The new features are in the API. You can find the new features in the v4.0.1 FlexLib API (may help to diff against v3.10.15 FlexLib). Discovery will report the capabilities of the features. You can attempt to enable a feature that isn't present, but the radio will just reject those attempts. Let us know if you have specific questions about the API changes.
  • K9YK
    K9YK Member ✭✭
    Will the documentation be updated to cover the API integration and the new features? I'm not using FlexLib at all and shouldn't have to reverse engineer the API changes from a library I'm not using, written in a language I'm also not using.
    Documentation updates should be included in the acceptance criteria for all new feature releases.
