Problem with V4
Hi all.
I downloaded V4 without a hitch and used it with my 6700 flawlessly until I tried to change to 17mts.
The rig temporarily closes and then re-starts and a message appears saying the program has lost contact please restart. I then need to close the program and restart it and create a slice.
I have tried simply typing each of the bands into the Flag in turn without any other programs running and the only failure is 17mts.
Anyone suggestions.
73, Duncan
  • Duncan G4ZOY
    Duncan G4ZOY Member ✭✭
    Answer ✓
    Thanks Al ,
    Factory reset worked but loading old profiles **** it again.
    Second reset and new profiles working fine.
    73, Duncan.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Duncan,
    I would recommend, exporting your profiles and do a factory reset. Then test 17m again, If that works, import your profile and see if 17m still works. if it still fails contact the help desk.
    AL, K0VM
