Latest 4.0.1 version issue
Hi all
I was using SmartSDR version 2.12.1 on a 6500 and Windows 10 .
I downloaded version 4.0.1 and after connecting, after about 1 minute of good functioning, I got a message saying :
SmartSDR has lost connection to the radio. Please reconnect.
This happens repeatedly over and over again. The Flerx will switch on and off by itself, without me intervening.
I downgraded to version 2.12.1 and the same thing happens again.
So in other words I cannot use my Flex !
What should I do ?
Side question : when upgrading, are the Smart CAT and SmartDAX settings carried over ?
Thanks + 73
Paul F6EXV
CAT and DAX are carried over. Open a Help Desk ticket, Paul. They will get your radio working. Without their input you might make matters worse.
Thanks Erik. Just did it !
Erik, How did your install go?
I used all the procedures used over the last year of booting and rebooting, shutting down radio after firmware upgrade. I even didn't back up my profiles…. I know all my settings by heart and if there were issues I would just recreate fresh new ones. My radio came right up and seemed fine. When I rolled up my dollar bills and shoved them into the DVD slot to pay for my v4 license subscription the only thing I had to do was hit the refresh button on Radio Settings to get the green button. And my account which I had bought other stuff before said the password was wrong. I used the same password saved in windows EDGE passwords, and my account came up then. So it just hickuped. I wouldn't call these things problems.
I wonder if there's funky network foibles at some of the stations causing problems, or they forgot to do the shut down and cold restart of the radio. I'm not even talking factory resets. I haven't needed to do that in about 4 upgrades. Erika K0DD0 -
Hello Erika, I hope you are keeping well.
On my 6400M, smooth as silk. On my 8400M the update got stuck and the radio stayed on the pink light for 45 minutes until I got a error box "update timed out". I rebooted and the update completed. So a minor hiccup, not a major problem. As you say, use common sense and best practice and there ought not to be any issues or at least, as in my case, the odd glitch is easily rectified.
Erik ❤️
Well, I installed 4.0.1 on my 6600. Had to get support to fix the licensing so it install. Now thats installed, I can not change bands. 80 meters only
This is the first time ive ever had issues upgrading software. Ill open another ticket and see if it can be resolved
Hi Scott, you might want to export your profiles and do a factory reset. If that does not resolve the issue, submit a help desk ticket.
I did open an help desk ticket. I have no saved profiles so not sure there is anything to export?
The profile export also exports all your current settings, so the radio comes back to where you left it after a profile import.
Tim got back to me and had me do a reset, but holding the power button until it turned white. This time after restarting, everything was working as expected.
My hats off to Flex Radio support!
Thanks to support, the update is now working fine, and version 4.0.1 goes fine… except keying the amp…
I do have the RCA TX1 enabled in the radio settings, 0 timing, and RCA "active low". But the amp will not be keyed. What I am missing that would be different from previous versions ?
TU + 73
Paul F6EXV
I don't know Paul but I would check Settings > TX Band Settings and ensure that there are check marks in RCA TX1.
That is the case, Erik, as I have indicated in my message…
I thought you were referring to
where no setting here enables amp PTT and I was referring you to TX Band Settings instead
That's how I got it here too… (basically)
I am sure that there is no other setting that activates / deactivates PTT to external devices connected to the RCA port(s). That there is a failure coinciding with the software upgrade is bizarre and, if a hardware issue eg cabling cannot be attributed to it, I would open another Help Desk ticket.
I will check the cable before I do that…
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
