4.0.1 is a bummer so far.
I installed it on my 6700. It opened all right, but disconnected in a couple of minutes. I did every kind of computer/radio reset I could think of; uninstalled/reinstalled several times. After a factory reset it would work for a short period of time, but then disconnect. When it disconnected the pan adapters went away leaving the radio controls next to a grey screen. The audio continued, and I couldn't close the app, even with Task Manager. Had to power down the 6700 to get it to go away, then start over again. I am very anxious to see a resolution as I have already purchased both subscriptions.
    Hi Edwin, I would submit a help desk ticket.
  • John, G3WKL
    John, G3WKL Member ✭✭
    Edwin
    I would be interested in the outcome to your ticket, as I am holding back from upgrading my 6700 from v2.12.1 to v4.0.1 having seen your post, and others that suggest there is an issue with the upgrade from v2.12.1 on some 6xxx radios
    Good luck
    73 John, G3WKL
