Remote control Flexradio Aurora 510?
OE4UFB
OE4UFB Member ✭✭
edited October 2025 in Aurora
Hi OMs and YLs,
i am absolutely new to Flexradio and would like to know a few things...
I like to make CW QSOs with Windows 11 over a VPN (OpenVPN) to a Flexradio Aurora 510 in my Shack. Is it possible and how is the performance/delay?
Do I need extra hardware to connect the paddle or key to the Windows 11 Notebook?
regards / 73 de OE4UFB
  • N5NHJ
    N5NHJ Member ✭✭✭
    Hi OE4UFB,
    Paddle or Straight key can't be used for CW remote with a Windows computer.
    One possible solution is using the MorCoNI network keyer.
  • OE4UFB
    OE4UFB Member ✭✭
    Hi Max,
    thank you for the info!
  • OE4UFB
    OE4UFB Member ✭✭
    So, the Maestro is the standard out-of-the-box solution for remotely operating the FlexRadio?
    Is it possible to detach the Maestro from the 510M and use it for remote operation, or do I have to buy the 510 and the Maestro separately?
  • Trucker
    Trucker Member ✭✭✭✭
    Separately. The front panel of an M model radio isn't removable.
  • OE4UFB
    OE4UFB Member ✭✭
    OK, thank you James!
  • David Decoons, wo2x
    @OE4UFB The Maestro allows the CW key to be plugged into it and provides local side tone. Another option for remote CW is the MorConi. It is a small box that connects to your network at the remote operating position and can work with various CW keying. It also has a speaker output for local sidetone as well as adjustable keying speed. See more details at https://www.morconi.comError
    73 Dave wo2x
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Or, just buy the maestro! Same capabilities with more Flexability.
  • OE4UFB
    OE4UFB Member ✭✭
    TNX David and John for your comments!
    73 de OE4UFB
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    While it is not the key/paddle experience, you can use the CWX window in the software to do keyboard CW
