Remote control Flexradio Aurora 510?
i am absolutely new to Flexradio and would like to know a few things...
I like to make CW QSOs with Windows 11 over a VPN (OpenVPN) to a Flexradio Aurora 510 in my Shack. Is it possible and how is the performance/delay?
Do I need extra hardware to connect the paddle or key to the Windows 11 Notebook?
regards / 73 de OE4UFB
Hi OE4UFB,
Paddle or Straight key can't be used for CW remote with a Windows computer.
One possible solution is using the MorCoNI network keyer.
Hi Max,
thank you for the info!
730 -
So, the Maestro is the standard out-of-the-box solution for remotely operating the FlexRadio?
Is it possible to detach the Maestro from the 510M and use it for remote operation, or do I have to buy the 510 and the Maestro separately?0 -
Separately. The front panel of an M model radio isn't removable.
OK, thank you James!1
@OE4UFB The Maestro allows the CW key to be plugged into it and provides local side tone. Another option for remote CW is the MorConi. It is a small box that connects to your network at the remote operating position and can work with various CW keying. It also has a speaker output for local sidetone as well as adjustable keying speed. See more details at https://www.morconi.comError
73 Dave wo2x
Or, just buy the maestro! Same capabilities with more Flexability.
TNX David and John for your comments!
73 de OE4UFB0 -
While it is not the key/paddle experience, you can use the CWX window in the software to do keyboard CW
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
