I upgraded from a Flex 6600 to a Flex 8600
mdestabrook
in DAX
The reception is great! But I have no TX Stream…I have Identified a DAX Channel which operates normally and the MIC Screen is on and streaming…My Power and Tuner Genius are up but cannot identify either antenna, so it won't tune and won't transmit with or without the power genius. All of the Software is upgraded. I have checked all my settings and they are the same as with the 6600…the TX band settings started out with every band "checked" under RCA TX3…the guide says that all these should be set to "0". Tuner says "No Band Data"
Turn off Windows Firewall and see if it starts working.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
