Can Antenna Genius handle transverters?
Bill_NO4ON
Bill_NO4ON Member ✭✭
edited October 2025 in Tuner Genius XL
I am new to Flex. I have an Antenna Genius and Q5 VHF and UHF transverters. I have a Diamond V2000B vertical connected to a Diamond MX72A Duplexor to supply VHF and UHF signals to the Q5's. I am also building a satellite antenna with VHF and UHF WIMO X Quad antennas feeding a MX72A for a single LMR-400 line to my shack. I could use a simple antenna switch to change from the vertical to the X Quads, but then what is the point of the Antenna Genius? Can the Antenna Genius be set up so that the Vertical is connected to Antenna Port 1, the Satellite is connected to Antenna Port 2, and the Antenna Port 3 is connected to a MX72A that feeds the Q5's. This would "maybe" allow me to use the Genius to switch the Antenna feed for the Q5's.
I bet that anyone else who has Transverters would be interested in this issue.
Bill - NO4ON
    Hi Bill, the Antenna Genius is only specified for frequencies up to 55 MHz, so I don't think it would be very well suited for this application.
