Squelch randomly stops working with transverter
I have a Q5 Signals transverter that I use with my Flex Radio 8600 to monitor a local repeater and my local hotspot. It is configured for the 2m / 144MHz band. I will usually tune to the repeater and just leave it running in a dedicated slice/panadapter while I work HF on other panadapters. I've noticed that at a seemingly random interval, squelch will stop functioning on that slice. Disabling/enabling squelch does not work. If I change from NFM to another mode and then switch back to NFM then squelch begins to work like normal. It happens at least once per day, but I haven't been able to nail down a pattern. Have any of you experienced this?
Here are some details on my system:
- Flex Radio 8600 running v3.10.10
- SmartSDR for Windows v3.10.10
- Windows 11 Pro 24H2 (10.0.26100 Build 26100)
- Q5 Signals Transverter L144-28HP75
- Squelch is set at 20
The issue was corrected in the SmartSDR v4.0.1 release. Thank you to the Flex Radio team for such a quick resolution!
Hi Don, I have a 6400 and don't see that issue at all. I would suggest submitting a help desk ticket.
I was just doing some testing and it happened on my second transverter as well. It's another Q5 Signals transverter, but it is for the 70cm / 440MHz band and is configured as XVTB in SmartSDR.
Hi Don, squelch happens in the radio, not the transverter, so this is a radio issue.
One thing to try is a factory reset to see if that clears it. Be sure to export your profiles first. If that doesn't help, submit a help desk ticket.
Unfortunately, a factory reset did not fix it. I will open a ticket and see what Flex has to say about it.
I got a response from Flex support, and it looks like it is a bug in SmartSDR. They have it logged as issue SMART-11556 if anyone else runs across it. Hopefully it will get fixed in a future release, but I imagine it is a pretty low priority problem. I'll try to reply here if I hear anything in the future.
- 651 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
