CAT entries have disappeared
Inexplicably, when I fired up SmartSDR this morning I found SmartSDR CAT was no longer showing the various CAT settings for N1MM, WSJT-X etc. I had about 10 definitions and now there are just two. It was working before and was working with the latest SmartSDR release.
I copied a backup of CAT.settings to ....users>name>AppData>Roaming>Flex Radio Systems and restarted but no change.
I uninstalled SmartSDR/CAT/DAX, rebooted, reinstalled. No change.
I read somewhere online that Profiles keep unique CAT settings. I am not sure that is true, but I did try loading my other profiles but it didn't change anything, I always just see two (I believe default) CAT entries.
Possibly related, but I also noticed that when I started SmartSDR, it started as a much smaller window than when I shut it down the night before. Almost as if some of the settings information for SmartSDR was not getting loaded too.
I am hoping there's a simple fix instead of having to recreate everything.
This happens to me regularly, since over a year or such CAT looses one or more ports after rebooting the PC. Earlier Versions did not show this habit.
Adrian before you go any further complete a help request. Flex personnel do a very good job helping with issues like the one you describe. This is not normal behavior. I'm not sure you did a backup but you can use SmartSDR Settings File Manager to complete a backup for when you have an issue.
Submit a helpdesk ticket for any guidance. I have this issue every few months where I lose all but one of the CAT definitions. Flex was not able to provide any resolution for me, so I have a workaround where I keep CAT definitions handy to manually re-enter.
Thx all. I recreated them today as I needed to be ready for the CWT contest. Having said that, Ronald, I don't see File Manager under SmartSDR>Settings. If you can point me in the right direction that would be great. Thanks again, 73.0
HI All. Also my Flex 8k6 has a sort of AI_Gost that "cancels" the CAT setup specially when working a radio-contest … but never during a daily QSOs activity …
not to mention all the other shortcomings
I am backupping everything is possible manually, but would it not be much easier to get a full backup automatically every n_minutes ??
free of course ☺️
73s
Phil
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 278 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
