SmartSDR not returing to same screen positions in Win11
Mimram
Hi All
Since installing Win 24-H on my PC I find that the Flex6700 will not return to the same screen setup as that which I switched it off, this is frustrating and help with this would be greatly received.
Mimram
Mimram
Did you close SSDR on the PC before you switched off the radio ??
AL, K0VM
In addition to Al's question, are you powering the radio off with the front panel button or REM ON jack on the back panel? If you simply shut down the power supply, that might be the issue.
