Balanced microphone
radioshopbob
I want to use a Suuntok BM6000 balanced cardio condenser microphone on my FLEX 6600M.
I requires voltage as does all condenser microphones, so does the 1/4 Microphone Balanced input jack provide that voltage? I know it does on the 3.5mm microphone input jack for unbalanced microphones. Please let me know, Bob W6MTM (w6mtm@verizon.net)
The radio does not supply voltage for a condenser mic. You will need a 48 volt phantom power supply. The phantom supply I have for my condenser mic uses XLR connectors. The mic is also XLR. You can buy or make a XLR to 1/4 inch connector to go from the phantom supply to the radio. Don't forget to select BAL in the P/CW panel.
Thank you so much.
Bob
- 396 Community Topics
- 676 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 277 SmartSDR for iOS
- 216 DAX
- 390 SmartSDR API
- 87 Aurora
- 328 FLEX-8000 Signature Series
- 985 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 146 Amateur Radio Interests
