Is Flex 6XXX with IC-2KL/LDG AT-600 Pro 2 Integration Possible?
aratner
aratner Member
I'm considering joining the Flex world but would like to integrate my legacy Icom IC-2KL amplifier and LDG antenna tuner. Is it possible to integrate these devices with the Flex 6XXX hardware to run as seamlessly as they do with my Icom transceiver?
  • Tim - W4TME
  • aratner
    aratner Member
    Tim,
    Good morning and thank you for passing this along so promptly.
    It looks as though the IC-PW1 is supported although the IC-2KL is not listed. Also, I was planning to run the FLEX from a Mac. Do you know of any Mac native-compatible options?
    Much appreciated!
    Adam KD5V
  • KB7FD
    KB7FD Member
    Mac-native control for my Flex 6700 via SmartSDR for Mac works very well, as does the ios version on the iPad
    Buzz - KB7FD
  • aratner
    aratner Member
    Buzz, very glad to hear! My question is can I control my Icom IC-2KL using the Mac/FLEX 6XXX? It turns out that my old IC-2KL has the 12/10 meter conversion and those bands are only selectable via CIV interface.
  • Bob- W5TX
    Bob- W5TX Member ✭✭
    Adam. Ran across this post while searching for another bit of info. I am running this combo currently. Unfortunately I’m a bit late to provide answer for solution - today is 09/14/2025. Hi.
    I have a schematic of design my son provided showing interface to IC-2KL. It uses the USB cable interface on my 6600M and a USB bit cable available from Flex. Consists of 2 IC’s and a few resistors and provides necessary band voltage, and 8V reference voltage required. Schematic available if you still have need.
    Bob W5TX
  • IK8MID
    IK8MID Member
    Hi, can you give me the diagram? Thanksnull
    null
