LSB not working properly on 40m
Anyone else had or have this issue? I am on 40m and my 8400 is showing LSB but on the band scope it is showing USB. Running the latest version or smart SDR. What could be causing this.
Best Answers
What happens when you select the 2.7k button?
Selecting the 2.7k button fixed it.
Any insight on why this happened?
Hi Jon, I would export profiles, then do a factory reset. If that doesn't solve it, submit a help desk ticket.
It maybe just a persistance issue that comes up from time to time, nothing to worry about and easily fixed.
Rob
I've noticed this on other bands as well. In the absence of a selected bandwidth, the default display on the panadapter looks like USB. As Rob mentioned, it seems somehow SmartSDR forgot the bandwidth selected/used the last time you were on 40m.
I do agree with Len tho, that it might be a good idea to export your profiles, do a factory reset, then import the profiles again — just to make sure everything is back where it should be.
BTW, if after importing your profiles, the problem recurs, then it's most likely a problem with the profiles. Those may need to be 'fixed' and re-saved. :-)
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
