Radio Panel Pop Out
I'm running out of vertical space on my monitor to display all of the components available in the radio panel.
With only one slice open, is it possible to pop out individual components and place them elsewhere?
Yes , hover your mouse pointer in the upper right hand corner of the container you wish to pop out and an arrow will appear that will allow you to move the container and it's controls anywhere on the screen. If you have dual monitors, you can even drag them over to the second monitor. To move them back hover the mouse pointer in the upper right hand corner again and click on the arrow pointing in the opposite direction. That will put it back on the main form.
That does not work for me. When I hover in the gray band across the top of the container I do not see an arrow in either corner.
I am able to drag it anywhere but once it is out side the radio panel I see only a blue circle with a diagonal line indicating that the action is not allowed. As soon as I release the mouse button the container reverts to the radio panel.
My bad! It moves the entire container outside the main display area. The arrow pointing towards the upper right is in the corner of the container where you can select the different Tabs for different functions. So,you cannot move individual controls. But you can move the entire control panel out of the main display window.
OK, I thought I was missing something, I often do…
It would be great to be able to move individual bits around.
There is not enough display height to fit all the individual components. And this is on a 2560 x1440 monitor.
Anyone else think that would be useful?
- 322 Shack Infrastructure
- 227 Networking
