JTDX is hosed up
I am using 3.10.10 and an 8600. Win 11. JTDX 2.2.160-rd7. The most recent upgrade has resulted in crazy JTDX behavior SDR opens normally. JTDX opens normally. The radio freq on the rig is the same as displayed in JTDX. The problem is the actual freq JTDX is looking at is skewed 3-4 Khz lower than what the vfo says. If I expand the JTDX graph out to 5000 I start seeing signals around 4400. On 20m the freq seems to be on FT4. Up until 10 am yesterday I had no problem with JTDX now it is hosed. WSJT works fine but I hate that program and its controls and poorer decodes for DX. Has anyone else seen this problem with JTDX? If so what was the solution.
I am fairly certain it is a JTDX problem. I have gone to cw and had people listen for me. The freq and signal is dead on what is expected. Is there an offset I am overlooking? I never have set an offset but maybe there is one.
You can see FT8 signals starting way way up high on the last one.
and just like that after 2 days I solved the problem. as usual something checked that shouldn't have been. Operator error.
So what was checked that should't be?
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
