FLEX 8K6 v31010 does not work with SDC Skimmer ....
Phil_EBV
Phil_EBV Member ✭✭
edited September 5 in Third-Party Software
... of course there will be some weeks till a working release between the two softwares
so I am thinking to downgrade to a v39xx or to my stable v3823 .
Is it safe to "downgrade" ?
Phil
IU0EBV
    Hi Phil, yes, it is safe to downgrade.
  • Phil_EBV
    Phil_EBV Member ✭✭
    HI Len, tnx for the advice, I have just downgraded to v3823, it works and keep the fingers crossed.
    Phil IU0EBV
  • Eric-KE5DTO
    We are aware of a problem introduced in SmartSDR v3.10.10 with the IQ Stream data format. We unintentionally changed the default format which will likely cause parsing errors for 3rd party applications using this interface. We plan to have a point release soon that addresses this issue. Our apologies for the problem and thanks for bringing it to our attention.
  • sysber
    sysber Member, Unconfirmed
    Hello,
    Any news on how this issue has been fixed? I had to downgrade as well.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Well, don’t hold your breath waiting or the “fix for the fix” to come out
  • Chris WX7V
    Chris WX7V Member ✭✭
    @Eric-KE5DTO Can Flex get this point release out soon! Its been a month, not fair to the 3rd party developers who are getting complaints and requests for support - especially slicemaster and sdc team. Tnx
  • F4BPO
    F4BPO Member, Unconfirmed ✭✭
    3.10.15 out and installed but still no luck for SDC on my side.
    Anyone else tried ?
  • g4ivv
    g4ivv Member ✭✭
    Yes its still broken for several people, including Yuri the SDC developer. It does seem to work for some people, but not for me either and I have reverted to 3.9.19 where everything is stable.
    Jonathan G4IVV
  • OK2WY
    OK2WY Member ✭✭
    There is workaround how to make skimmer working using the DAX IQ stream, but it works in 3.10.10 too. It does not solve unfunctional digi modem, since it use API data stream with wrong data format. It seems that this issue is not fixed yet.
    I am pretty disappointed how they solve bugs in software :(
    Interestingly, SDC failed for me under 3.10.10, but is fixed in 3.10.15. I am running a Flex 6400.
