Being prompted to buy a license after installing v3.10.10?
If you already had a SmartSDR v3 license and you're being prompted to buy a license after installing v3.10.10, please make sure that your radio has internet access. The radio is setup to pull licensing info automatically when connected to the internet and due to some changes made in this release, previous local copies of the license do not carry forward.
One common scenario is where you have the radio connected via ethernet directly to your laptop which accesses the internet via WiFi. In this config, the radio actually doesn't have internet access and won't be able to obtain your valid license (and will prompt you to buy). Connecting your radio to the internet for a single boot cycle should address this issue. At that point, you should be able to return to your original config, if desired.
If you do end up purchasing a license that you don't need, we will respond with a note to the effect that the license purchase is a duplicate and we will refund the purchase. If you continue to have trouble, please open a helpdesk ticket by visiting helpdesk.flexradio.com and we'll help you get things sorted out.
Thanks for posting this explanation, Eric. As I mentioned in my post in the other 3.10.10, I got caught in this with my rig that is directly connected to my PC — no connection to the LAN or internet at all.
Tim was able to get me fixed up, but for others like me, it will require you to disconnect the radio from the PC and temporarily connect to the internet.
I've been thinking about buying a switch to connect both the PC and the radio together and to the LAN, so maybe now I'll have to move that purchase forward :-)
I also ran into this (prompt to buy license) during 3.10.10 update … but an Internet connection and re-boot solved it for me.
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
