RadioSport RS60CF Headset
I purchased a Radiosport RS60CF Headset a few years ago from Flexradio. Does anyone happen to remember what microphone element came with the Headset?
Mark Griffin, KB3Z
It May depend upon which model you ordered initially.
Is this the "Anniversary Edition?" that has the Small, fixed Mic Element? If so, then it is the "M20" Element.
If you got the previous version with the larger, replaceable/interchangeable mic elements, you could have ordered it with one of several mic elements - M207, M208, M350, M360.
You may be able to carefully remove the foam "spit shield" cover and find a model number on the larger mic elements.Here is a link to more information from RadioSport:
I found out through a prior posting I had made on the Community. It is the M208. Thanks for the suggestions!
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
