RadioSport RS60CF Headset
I purchased a Radiosport RS60CF Headset a few years ago from Flexradio. Does anyone happen to remember what microphone element came with the Headset?
Mark Griffin, KB3Z
  • Ken Wells
    Ken Wells Community Manager admin
    It May depend upon which model you ordered initially.
    Is this the "Anniversary Edition?" that has the Small, fixed Mic Element? If so, then it is the "M20" Element.
    If you got the previous version with the larger, replaceable/interchangeable mic elements, you could have ordered it with one of several mic elements - M207, M208, M350, M360.
    You may be able to carefully remove the foam "spit shield" cover and find a model number on the larger mic elements.
    Here is a link to more information from RadioSport:
    Arlan Communications - Mic Options
  • Mark Griffin
    Mark Griffin Member ✭✭✭
    I found out through a prior posting I had made on the Community. It is the M208. Thanks for the suggestions!
