All SmartSDR CAT ports all show as 'Not Present'. Help...
Ok folks I have reached the 'pulling my hair out' phase with this issue. SmartSDR CAT is showing all of my ports as 'Not Present' (see attached screen shot). I have tried everything including completely uninstalling and reinstalling Smart SDR.
I'm running windows 11 and am fully up to date. Running latest version of SmartSDR. When looking at the device manager COM ports are present and report as working properly(see attached screen shot)
Anyone have a clue as to what the issue may be?
All help appreciated!
Update: I again uninstalled SmartSDR and also uninstalled FlexVSP. Reinstalled everything. SmartSDR CAT seems to install two ports by default. COM8 tied to Slice A and a TCP port 5002. Both are reporting as 'Not Present' in SmartSDR CAT.
As a side note my FlexControl (COM7) is working just fine.
I have to ask, I'm not near a radio, but is Slice A active?
Ok, I figured a workaround. If I explicitly pick a profile after starting up SmartSDR, the ports magically become present
"Not present" is reporting that the related slice (A,B,C,etc.) is not present ( not running ) in SSDR. Therefor nothing for the CAT port to work with.
And you found a solution for creating a Slice. I am surprised that there was not a slice running when your first started SSDR.
AL, K0VM
I had this same issue today for the first time. Coincidently I was reading this post and noticed the red Not Present in SmartCat for WSJT and Logger32. I first tried choosing a profile but that didn't work. Rebooting the computer fixed the problem. Win 11, v3.9.16, Flex 8600M.
I recently upgraded Windows and SmartSDR. The "Not Present" came up in CAT. After reading your post, I selected global profile of default SO2R and got rid of the Not Present. Thanks for sharing the work-around.
Win 11 24H2, v4.0.1, Flex 6600.
- 373 Community Topics
- 100 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 940 Maestro
- 54 FlexControl
- 999 Third-Party Software
