StreamDeck 404 Error
I just installed a 15 button Streamdeck at my remote site. I used the FrStack3 from my home station and installed same.
Streamdeck loads fine, but the buttons do not work and I have "err 404" in many of them. Obviously a Comms problem, but for the life of me I cannot corretc it.
URL 1 looks correct. The only anomaly I can see is that in the preview it is showing the URL twice ie: "http://127.0.0.1:13522/apihttp//127.0.0.1:13522" then the Parem. Is this correct?
Ports are open in the firwall.
Tim VE6SH
I found an old post and changed the FRStack.exe.config file from "true" to "false" as suggested and restarted FRStack as an administrator. Same issue.
FRStack. Click Help in upper right, then REST help.
Under URL1 you want http://127.0.0.1:13522/api then under param you add the parameter. Someplace you have the URL twice.
73 Dave wo2x
- 322 Shack Infrastructure
- 227 Networking
