radio setup callsign box with blanks
mark zelesky
Hello, I am wondering if there is a workaround so you could put your callsign and name in the callsign box under the radio setup tab with spaces in between. I can do display name and callsign with two periods or dashes in between but spaces won't work. If I put in spaces, when I hit the enter key the spaces go away and name and callsign are joined together. I just want it to display on the 6700 without the periods and just spaces. Thanks
Hi Mark, the Flex API uses spaces as separators between parameters, so it is not possible to use them within a parameter.
You might find a non-displayable character that would work to present like a space, but it would take some experimentation.
I just use a dot in my radio's nick name field.
-1
Or another kludge,use a slash/.
- 396 Community Topics
- 676 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 328 FLEX-8000 Signature Series
- 985 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 146 Amateur Radio Interests
