Shutdown 8600 via Smartsdr?
PhilM
Is it possible to shutdown the 8600 via smartsdr or do i always have to manually power down the box from the button on the front after exiting SMARTSDR?
Phil
NC3S
Phil
NC3S
Hi Phil, there is no shutdown command in SmartSDR. You either need to press the front power button or use the REM ON jack on the back of the radio. The REM ON jack is useful if your radio is not in easy reach or if you are operating remotely. To use it remotely, a cheap WiFi switch is a good way to go.
OK thanks, just thought I missed something,
Phil
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
