Problème DAX Driver
Best Answers
raphaël.s member ✭
4:38 AM
I just plugged in my new 8400ATU and installed the smartSDR v3.8.23 software. Everything works, except for the FHM-3 microphone. DAX tells me the drivers aren't correct, even after several installations.
Any ideas?
Thanks in advance, ON3PW 73Hi Raphael, which jacks is your FHM-3 plugged in to? Also, DAX needs to be off when using the mic.
Are you on Windows 11? There is a known issue that requires Core Isolation to be turned off to install and use DAX.
It would be helpful if you could post a screenshot of SmartSDR.
Hi Raphael, If you are running Windows 11, this will not work. You need to disable Core Isolation in Windows first. Are you using Windows 11?
Enjoy your new radio! You might want to upgrade to 3.9.19. It fixes some small issues.
Bonjour Len
J'ai essayé cette manœuvre mes sans résultat
https://helpdesk.flexradio.com/hc/en-us/articles/27702962401947-How-to-Manually-Install-Reinstall-DAX-Driver0 -
J'ai trouve j'ai désactiver l'isolation du noyau dans Windows.
Merci beaucoup Len 73's ON3PW Raphaël0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
