Update 3.9.19
Excellent job, FlexR. Well done. Faultless install/update to 6600M. The horrid looking screen when selecting Smart Control, before applying computer has now thankfully disappeared and the normal and usual interim presentation of the screen has been recovered.
Thank you again Flex Radio for your continued support and hard work!!
73 de Mike G4GWH
My 6400 upgraded perfectly. I can confirm that the interlock message at SmartSDR startup is gone. In the limited testing that I have done this morning, everything seems normal.
6600 upgraded no issues.
It is good to see the interlock issue has been resolved with the 6000 series as the release notes only mention the 8000's.
6300 upgraded without any issue, thanks.0
I was able to upgrade from 3.9.18 on 4 windows 11 PC's, a mix of 23h2 and 24h2 but one will not upgrade on Win11 23h2. The installation continues then disappears. Restoring win to a previous time and trying again...0
Solved it by uninstalling the previous 3.9.18 and 3.8.20 including the vsp drivers. Some drama to do it, the uninst directories under each flex version were missing the .msg and .dat files. Fortunately I had older disk backups I could retrieve those files from and then was able to uninstall the previous versions.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
