SmartSDR Serial Passthrough - API Documentation
Is there any API documentation available for the new SmartSDR Serial Passthrough?
73 Christian
I don't think the API has been updated. There are only a few relevant ethernet API changes. First, setting a usb cable type to passthrough:
usb_cable set <serialNumber> type=passthroughThen SmartSDR CAT interacts with the data by receiving base64 data (by default) from the USB Cable via status message from the radio:
usb_cable data:base64 <encoded string>And sends data from the local virtual port to the radio:
usb_cable write <serialNumber> base64 <base64encodeddata>Hopefully that answers your questions. We will get this updated in the API soon (logged in our system as SMART-11468).
Hi Christian, I don't think any new API documentation has been released in a while.
Thank you very much Eric, it works perfectly! 😎
73 Christian, HB9HJQ
- 685 The Flea Market
- 195 SmartSDR+
- 102 Aurora
- 994 Maestro
- 971 Genius Products
- 357 Tuner Genius XL
- 133 Antenna Genius
