FLEX-6600M on Mac 2 panadapters only.
EA7Z
Hello:
I have a FLEX-6600M running SmartSDR on a Mac mini M4, and I can only get two panadapters at most. It should be four. What could be the problem? Thanks.
Do you have panadapters showing on your “M” front panel? The 4 panadapters are total for all GUI connections.
No, i do not have pan adapters showing on my M front panel.0
2.9 software?
Shut radio off and wait two minutes, disconnect power physically from radio.
Do a factory Reset by:
Reconnect power to radio, wait two minutes and then push and hold radio power button til it turns white.It will reset to 20m. Now see if you get 4 panadapters.
Hi again:
I solved the problem. I changed to v3.8.23 and works fine. If I go back to the latest version it fails again. It does not work doing a factory reset at least in version 3.9.18.
Thanks a lot.0 -
Salvador -
If you have not already done so, I strongly suggest you send a bug report to Marcus (Mac SmartSDR author) by opening the app and clicking on Help→Contact Support.
This sounds like a pretty serious issue, and Marcus has been very responsive to bug reports.
Cheers
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
